How To Do Grouping Of HomeMate Smart Products Using HomeMate Smart App
What you need to get started
- Atleast two HomeMate Smart Products already added on the HomeMate Smart
App.
- Phone must be connected to 2.4 Ghz WiFi network only (and not 5 Ghz).
- Location should be ON.
- Mobile Bluetooth should be ON.
- Download HomeMate Smart App from App Store or Google Play.
- Use link to download HomeMate Smart app - https://a.smart321.com/homematesmart
- You can scan the QR code below to download the HomeMate
Smart App:
You can also search “HomeMate Smart” in either
App Store or Google Play to install the App.
4. Set location.
Steps To Do Grouping Of Smart Lighting Products Using HomeMate Smart App
- Open the HomeMate Smart App.
- Make sure atleast two HomeMate Smart lighting products already added.
- Tap on any of the Smart Lighting Product like "Smart LED Strip 2"
- On top right corner tap on pencil mark.
- Now tap on "Create Group"
- Select all the products that support Group Mode.
- Tap on "Save" on top right.
- You can name the group like "Smart LED Strip Group" then click on "Save"
- Now the "Smart LED Strip Group" will be added.
- Tap on "Smart LED Strip Group" to control all the added products together.
Important links:
For Alexa linking process, click here.
For Google Assistant linking, click here.
For whatsapp support, click here
For any issue or query, mail us at support@homemate.co.in or call +91-838-404-8232 between 10 am to 6 pm.
