Product Features of HomeMate 16A 1 Node Smart Switch
What you need to get started
  1. HomeMate 16A 1 Node Smart Switch  must be added on the HomeMate Smart App.
  3. Location should be ON.
      4. Set location.
Countdown Timer
You can use Countdown Timer feature to Turn On or Off the Smart 1 Node Switch
If the Switch is at OFF position, the Countdown Timer will Turn ON the Smart 1 Node Switch.
  1. Tap On "Timer"
  2. Set the Countdown Timer.
  3. Tap on "Play Button" to start the countdown timer.
  4. The Smart 1 Node will Turn ON after 10 mins as showing on the Screen.
If the Switch is at ON position, the Left Time will Turn OFF the Smart 1 Node Switch.
  1. Tap On "Timer"
  4. The Smart 1 Node will Turn OFF after 10 mins as showing on the Screen.
Schedule
You can use Schedule Feature to create a Schedule to Turn On and Off the Smart Product according to Time, day etc.
  1. Tap on "Timer"
  2. Tap on "Schedule"
  3. Tap on "Add Schedule"
  4. Set the timings and select the Weekdays and also set the Switch position On or Off. Then Tap on "Save"
  5. You can make as many Schedule as you want.
Settings
You can go to setting to change the power on/off behavior of the 1 Node Smart Switch
  1. Tap on "Setting"
  2. You can set the Power On behavior
    • Product Features of HomeMate 2 Node Smart Switch
      What you need to get started HomeMate 2 Node Smart Switch must be added on the HomeMate Smart App. Phone must be connected to 2.4 Ghz WiFi network only (and not 5 Ghz). Location should be ON. Mobile Bluetooth should be ON. Download app and Register ...
    • Product Features of HomeMate 4 Node Smart Switch
      What you need to get started HomeMate 4 Node Smart Switch must be added on the HomeMate Smart App. Phone must be connected to 2.4 Ghz WiFi network only (and not 5 Ghz). Location should be ON. Mobile Bluetooth should be ON. Download app and Register ...
    • Product Features of Smart Switch Breaker
      What you need to get started HomeMate Smart Switch Breaker must be added on the HomeMate Smart App. Phone must be connected to 2.4 Ghz WiFi network only (and not 5 Ghz). Location should be ON. Mobile Bluetooth should be ON. Download app and Register ...
    • Product Features of HomeMate Smart Fan Retrofit
      What you need to get started HomeMate Smart Fan Retrofit Kit must be added on the HomeMate Smart App. Phone must be connected to 2.4 Ghz WiFi network only (and not 5 Ghz). Location should be ON. Mobile Bluetooth should be ON. Download app and ...
    • Product Features of HomeMate Smart Plug 10A
      What you need to get started HomeMate Smart Plug 10A must be added on the HomeMate Smart App. Phone must be connected to 2.4 Ghz WiFi network only (and not 5 Ghz). Location should be ON. Mobile Bluetooth should be ON. Download app and Register ...
