Product Features of HomeMate 2 Node Smart Switch
What you need to get started
  1. HomeMate 2 Node Smart Switch  must be added on the HomeMate Smart App.
  3. Location should be ON.
      4. Set location.
COUNTDOWN TIMER
You can use Countdown Timer feature to Turn On or Off the 2 Node Smart Switch
If the 2 Node Smart Switch is at ON position, the Countdown Timer will Turn OFF the 2 Node Smart Switch.
  1. Tap On "Timer"
  2. Select Switch 1 or Switch 2.
  3. Set the Countdown Timer.
  4. Tap on "Play Button" to start the countdown timer.
  5. The 2 Node Smart Switch will Turn Off after 5 mins as showing on the Screen.
If the 2 Node Smart Switch is at OFF position, the Countdown Timer will Turn ON the 2 Node Smart Switch.
SCHEDULE
You can use Schedule Feature to create a Schedule to Turn On and Off the Smart Product according to Time, day etc.
  1. Tap on "Timer"
  3. Tap on "Schedule"
  4. Tap on "Add Schedule"
  5. Set the timings and select the Weekdays and also set the Switch position On or Off. Then Tap on "Save"
  6. You can make as many Schedule as you want.
CIRCULATE
You can use Circulate Feature to create a Schedule to Turn On and Off the Smart Product between a particular Time Gap.
  1. Tap on "Timer"
  3. Tap on "Circulate"
  4. Tap on "Save"
RANDOM
You can use Random Feature to create a Schedule to Turn On and Off according to a time period and it will operate the 2 Node Smart Switch in Smart Mode.
  1. Tap on "Timer"
  3. Tap on "Random"
  4. Tap on "Save"
INCHING
You can use Inching Feature to put the device in an Automatic State: that is, each time the device is turned on, it will automatically turn off after a period of operation.
  1. Tap on "Timer"
  3. Tap on "Inching"
  4. Set the time and slide the inching button to save the settings.
OPTIONAL SETTINGS
  1. Tap on "Setting"
  2. You will see different options
  3. Tap on "Relay Status" to change the default state of 2 Node Smart Switch when the electricity goes Off and comes back On.
  4. Tap on "Light Mode" to change the Indicator LED settings of the 2 Node Smart Switch.
HomeMate 2 Node smart Switch purchase links: Website - Click here and Amazon - Click here
    • Product Features of HomeMate 4 Node Smart Switch
      What you need to get started HomeMate 4 Node Smart Switch must be added on the HomeMate Smart App. Phone must be connected to 2.4 Ghz WiFi network only (and not 5 Ghz). Location should be ON. Mobile Bluetooth should be ON. Download app and Register ...
    • Product Features of HomeMate 16A 1 Node Smart Switch
      What you need to get started HomeMate 16A 1 Node Smart Switch must be added on the HomeMate Smart App. Phone must be connected to 2.4 Ghz WiFi network only (and not 5 Ghz). Location should be ON. Mobile Bluetooth should be ON. Download app and ...
    • Product Features of Smart Switch Breaker
      What you need to get started HomeMate Smart Switch Breaker must be added on the HomeMate Smart App. Phone must be connected to 2.4 Ghz WiFi network only (and not 5 Ghz). Location should be ON. Mobile Bluetooth should be ON. Download app and Register ...
    • Product Features of HomeMate Smart Fan Retrofit
      What you need to get started HomeMate Smart Fan Retrofit Kit must be added on the HomeMate Smart App. Phone must be connected to 2.4 Ghz WiFi network only (and not 5 Ghz). Location should be ON. Mobile Bluetooth should be ON. Download app and ...
    • Product Features of HomeMate Smart Plug 10A
      What you need to get started HomeMate Smart Plug 10A must be added on the HomeMate Smart App. Phone must be connected to 2.4 Ghz WiFi network only (and not 5 Ghz). Location should be ON. Mobile Bluetooth should be ON. Download app and Register ...
