What you need to get started
- HomeMate Smart Door Sensor must be added on the HomeMate Smart App.
- Phone must be connected to 2.4 Ghz WiFi network only (and not 5 Ghz).
- Location should be ON.
- Mobile Bluetooth should be ON.
- Download HomeMate Smart App from App Store or Google Play.
- Use link to download HomeMate Smart app - https://a.smart321.com/homematesmart
- You can scan the QR code below to download the HomeMate
Smart App:
You can also search “HomeMate Smart” in either
App Store or Google Play to install the App.
4. Set location.
App Interface
- Tap on the HomeMate Door sensor that is already added
- You can see the Door Sensor active position, when the Door open and Close.
- To check the Door sensor open and closed history, tap on the "History"
- To get open and close notifications tap on "Alarm"
- Turn On all the notifications
- You will get notification once you enable Door Sensor Open and Close Alarm
- The Battery indicator will show you the remaining battery. High Means 100%
Important links:
For Alexa linking process, click here.
For Google Assistant linking, click here.
For whatsapp support, click here
HomeMate Smart Door Sensor purchase links: Website - Click here and
Amazon - Click here
For any issue or query, mail us at support@homemate.co.in or call +91-838-404-8232 between 10 am to 6 pm.
