Product Features of HomeMate Smart Fan Regulator Touch Switch White/Black
What you need to get started
  1. HomeMate Smart Fan Regulator Touch Switch must be added on the HomeMate Smart App.
  3. Location should be ON.
      2. Open App and register your account.
      3. Create Home in Home Management Setting.
      4. Set location.
FAN SPEED CHANGE
You can change the Fan speed by sliding the speed bar to 1,2,3,4 or 5
  1. Slide the speed bar to change the speed, you can see the current speed like it is showing 5
  2. If you click on Switch the Fan will turn Off
SCHEDULE
You can use Schedule Feature to create a Schedule to Turn On and Off the Smart Product according to Time, day etc.
  1. Tap on "Timer"
  2. Tap on "Add Schedule"
  3. Set the timings and select the Weekdays and also set the Fan Switch position On or Off. Then Tap on "Save"
  4. You can make as many Schedule as you want.
OPTIONAL SETTINGS
  1. Tap on "Settings"
  2. You can turn on and off the child lock
HomeMate HomeMate Smart Fan Regulator Touch Switch White/Black purchase links: Website - Click here and Amazon - Click here
    • Product Features of HomeMate Smart Fan Retrofit
      What you need to get started HomeMate Smart Fan Retrofit Kit must be added on the HomeMate Smart App. Phone must be connected to 2.4 Ghz WiFi network only (and not 5 Ghz). Location should be ON. Mobile Bluetooth should be ON. Download app and ...
    • Product Features of HomeMate 2 Node Smart Switch
      What you need to get started HomeMate 2 Node Smart Switch must be added on the HomeMate Smart App. Phone must be connected to 2.4 Ghz WiFi network only (and not 5 Ghz). Location should be ON. Mobile Bluetooth should be ON. Download app and Register ...
    • Product Features of HomeMate 4 Node Smart Switch
      What you need to get started HomeMate 4 Node Smart Switch must be added on the HomeMate Smart App. Phone must be connected to 2.4 Ghz WiFi network only (and not 5 Ghz). Location should be ON. Mobile Bluetooth should be ON. Download app and Register ...
    • Product Features of HomeMate 16A 1 Node Smart Switch
      What you need to get started HomeMate 16A 1 Node Smart Switch must be added on the HomeMate Smart App. Phone must be connected to 2.4 Ghz WiFi network only (and not 5 Ghz). Location should be ON. Mobile Bluetooth should be ON. Download app and ...
    • Product Features of Smart Switch Breaker
      What you need to get started HomeMate Smart Switch Breaker must be added on the HomeMate Smart App. Phone must be connected to 2.4 Ghz WiFi network only (and not 5 Ghz). Location should be ON. Mobile Bluetooth should be ON. Download app and Register ...
