What you need to get started
- HomeMate Wi-Fi RGB LED KIT 5 Mtr.
- Phone must be connected to 2.4 Ghz WiFi network only (and not 5 Ghz).
- Location should be ON.
- Mobile Bluetooth should be ON.
- Download HomeMate Smart App from App Store or Google Play.
- Use link to download HomeMate Smart app - https://a.smart321.com/homematesmart
- You can scan the QR code below to download the HomeMate
Smart App:
You can also search “HomeMate Smart” in either
App Store or Google Play to install the App.
4. Set location.
CHANGING RGB COLORS ON RGB LED KIT
- You can change the colors of Smart RGB LED KIT by selecting the color using
slider or by tapping the preset colors.
- For Brightness control slide the Brightness slider
SCENE SELECTION
- You can select preset Scene by tapping on the Scene selection mode and selecting
the scene according to your mood.
- You can also make a custom scene, select the color and mode then click on
save.
MUSIC MODE
- Tap on the "Music" mode to make the Smart RGB LED KIT change colors according
to the music.
- You can set the sensitivity by tapping on sensitivity icon.
- You can try "App mode" so that your phone microphone will detect the music
and the strip light will respond accordingly.
- Tap on Play button to start
MORE FEATURES (PLAN)
- Tap on "More features"
- Tap on "Plan" and then tap on "Add" there will be different options under
"Plan" like Sleep Plan, Wake up plan. You can choose accordingly.
- Sleep Plan, select timings and turn on "Customize" then tap on "Save" it
will get added under Plan
- Wake Up Plan, select timings and turn on "Customize" then tap on "Save" it
will get added under Plan.
- Plan added will be shown on the Plan Screen, the Smart RGB LED Kit will work
according to the Plan.
MORE FEATURES (SCHEDULE)
- Tap on "More" then "Schedule"
- Tap on Add to add Schedule. After choosing the timing and behavior tap on
"Save" to save the Schedule.
MORE FEATURES (LEFT TIME)
- Tap on "More" then "LEFT Time"
- Set the time and click on confirm
MORE FEATURES (POWER ON BEHAVIOR)
Tap on "More" then "Power On Behavior"
- Select the Behavior of the Smart RGB LED Kit during power cut off.
Important links:
For Alexa linking process, click here.
For Google Assistant linking, click here.
For whatsapp support, click here
HomeMate HomeMate Wi-Fi RGB LED KIT 5 Mtr purchase links: Website - Click here and
Amazon - Click here
HomeMate HomeMate Wi-Fi RGB LED KIT 10 Mtr purchase links: Website - Click here and
Amazon - Click here
For any issue or query, mail us at support@homemate.co.in or call +91-838-404-8232 between 10 am to 6 pm.
