Product Features of Smart Bulb 9W E27
What you need to get started
  1. HomeMate Smart Bulb E27.
  3. Location should be ON.
      4. Set location.
CHANGING RGB+CCT COLORS ON SMART BULB
  1. You can change the colors of Smart Bulb by selecting the color using slider or by tapping on the preselected colors on the top like Cool White, Warm White etc.
  2. For Brightness control slide the Brightness slider on Top.
  3. For RGB colors Swipe this screen to right you will see RGB colors to choose using slider.
SCENE SELECTION
  1. You can select preset Scene by tapping on the Scene selection mode and selecting the scene according to your mood.
  2. The Smart Bulb will start showing selected scene after you have selected it.
MUSIC MODE
  1. Tap on the "Music" mode to make the Smart Bulb change colors according to the music.
  2. Tap on "Start" to use your Phone Microphone for Music Mode.
MORE FEATURES (PLAN)
  1. Tap on "More" then tap on "Plan"
  2. Tap on "Plan" and then tap on "Add"
  3. There will be different options under "Plan" like Random Timing, Cycle Timing, Sleep Plan, Wake up plan.
  4. Random Timing, select timings and turn on "Customize" then tap on "Save" it will get added under Plan.
    WhatsApp_Image_2022-06-21_at_3.12.27_PM__1_.jpegWhatsApp_Image_2022-06-21_at_3.12.28_PM.jpeg
  5. Cycle Timing, select Opening and Closing Time and Customize Turn On then Tap on "Save" it will get added under Plan.
  6. Sleep Plan, select timings and turn on "Customize" then tap on "Save" it will get added under Plan.
  7. Wake Up Plan, select timings and turn on "Customize" then tap on "Save" it will get added under Plan.
  8. Plan added will be shown on the Plan Screen, the Smart Bulb will work according to the Plan.
MORE FEATURES (SCHEDULE)
  1. Tap on "More" then "Schedule"
  2. Tap on Add to add Schedule. After choosing the timing and behavior tap on "Save" to save the Schedule.
  3. You can make as many Schedule you want.
MORE FEATURES (TIMER)
  1. Tap on "More" then "Timer"
  2. You can use Timer Function to Turn On/Off the Smart Plug after a certain period of time.
    If you Bulb is On, the Timer will Turn Off the Bulb, if the Bulb is Off the Bulb will Turn On the Smart Bulb.
  3. After selecting the time, tap on "Confirm" to start the Timer.
MORE FEATURES (BIORHYTHM)
  1. Tap on "More" then "Biorhythm"
  2. You can set behavior of the Smart Plug to like the Smart Bulb will behave around the clock. Turn on the Biorhythm using Slider and then select the timings and behavior.
       WhatsApp_Image_2022-06-21_at_3.12.34_PM__1_.jpegWhatsApp_Image_2022-06-21_at_3.12.34_PM__2_.jpeg
MORE FEATURES (POWER ON BEHAVIOR)
  1. Tap on "More" then "Power On Behavior"
  2. Select the Behavior of the Smart Plug during power cut off.
    • Product Features of Smart Bulb 9W B22
      What you need to get started HomeMate Smart Bulb B22 added on the HomeMate Smart App. Phone must be connected to 2.4 Ghz WiFi network only (and not 5 Ghz). Location should be ON. Mobile Bluetooth should be ON. Download app and Register account ...
    • Product Features of Smart Downlight 15W
      What you need to get started HomeMate Smart Downlight 15W. Phone must be connected to 2.4 Ghz WiFi network only (and not 5 Ghz). Location should be ON. Mobile Bluetooth should be ON. Download app and Register account Download HomeMate Smart App from ...
    • Product Features of Smart Surface Light 10W
      What you need to get started HomeMate Smart Surface Light 10W. Phone must be connected to 2.4 Ghz WiFi network only (and not 5 Ghz). Location should be ON. Mobile Bluetooth should be ON. Download app and Register account Download HomeMate Smart App ...
    • Product Features of Smart Downlight 9W
      What you need to get started HomeMate Smart Downlight 9W. Phone must be connected to 2.4 Ghz WiFi network only (and not 5 Ghz). Location should be ON. Mobile Bluetooth should be ON. Download app and Register account Download HomeMate Smart App from ...
    • Product Features of HomeMate Smart Video Doorbell
      What you need to get started HomeMate Smart Video Doorbell must be added on the HomeMate Smart App. Phone must be connected to 2.4 Ghz WiFi network only (and not 5 Ghz). Location should be ON. Mobile Bluetooth should be ON. Download app and Register ...
