Product Features of Smart Downlight 15W
What you need to get started
  1. HomeMate Smart Downlight 15W.
  3. Location should be ON.
      4. Set location.
CHANGING RGB+CCT COLORS ON SMART Downlight 15W
WHITE
  1. You can change the white colors of Smart Downlight 15W by selecting the color using slider,
  2. For Brightness control slide the Brightness slider.
RGB COLORS
  1. For RGB colors, tap on "color" you will see RGB colors to choose using slider.
SCENE SELECTION
  1. For Scene selection, tap on "Scene" you will see RGB colors to choose using slider.
  2. The Smart Downlight 15W will start showing selected scene after you have selected it.
MUSIC MODE
  1. Tap on the "Music" mode to make the Smart Downlight 15W change colors according to the music.
  2. The Downlight will respond according to the music playing.
MORE FEATURES (SCHEDULE)
  1. Tap on "More" then tap on "Schedule"
  2. Tap on "Schedule" and then tap on "Add"
  3. You can add schedule and select behavior of the downlight. Then click on "Save" to save the schedule.
  4. You can add as many schedule as you want.
MORE FEATURES (POWER ON BEHAVIOR)
  1. Tap on "More" then "Power On Behavior"
  2. Select the Behavior of the Smart Plug during power cut off.
    • Product Features of Smart Downlight 9W
      What you need to get started HomeMate Smart Downlight 9W. Phone must be connected to 2.4 Ghz WiFi network only (and not 5 Ghz). Location should be ON. Mobile Bluetooth should be ON. Download app and Register account Download HomeMate Smart App from ...
    • Product Features of Smart Bulb 9W B22
      What you need to get started HomeMate Smart Bulb B22 added on the HomeMate Smart App. Phone must be connected to 2.4 Ghz WiFi network only (and not 5 Ghz). Location should be ON. Mobile Bluetooth should be ON. Download app and Register account ...
    • Product Features of Smart Bulb 9W E27
      What you need to get started HomeMate Smart Bulb E27. Phone must be connected to 2.4 Ghz WiFi network only (and not 5 Ghz). Location should be ON. Mobile Bluetooth should be ON. Download app and Register account Download HomeMate Smart App from App ...
    • Product Features of Smart Surface Light 10W
      What you need to get started HomeMate Smart Surface Light 10W. Phone must be connected to 2.4 Ghz WiFi network only (and not 5 Ghz). Location should be ON. Mobile Bluetooth should be ON. Download app and Register account Download HomeMate Smart App ...
    • Product Features of HomeMate Smart Video Doorbell
      What you need to get started HomeMate Smart Video Doorbell must be added on the HomeMate Smart App. Phone must be connected to 2.4 Ghz WiFi network only (and not 5 Ghz). Location should be ON. Mobile Bluetooth should be ON. Download app and Register ...
